Home > Technical > Panel sides to tub
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
Panel sides to tub
Hi folks,
I'm fitting my County sides to the tub and wondering how tight do I tighten the studs. Feels like I could make the 2 panels touch. I'm using the YRM seals. Any advice or help appreciated
Shane
Post #940842 3rd Feb 2022 7:38pm
Oldowner
The nuts on the studs should be done up tightly. The front panel fit can be adjusted using the adjustable L shaped bracket bolted to the tub sides. If not adjusted correctly the roof gutter can gain a slight bend when viewed along
Post #940848 3rd Feb 2022 7:56pm
shanecl
Great, I'll get tighten so. Was afraid to go too mad. Thanks for the tip on the front bracket. Just fitting fitting now 😁
Thanks for quick reply
Shane
Post #940855 3rd Feb 2022 8:11pm
