![]() | Home > Technical > Panel sides to tub |
| Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 683
The nuts on the studs should be done up tightly. The front panel fit can be adjusted using the adjustable L shaped bracket bolted to the tub sides. If not adjusted correctly the roof gutter can gain a slight bend when viewed along
| shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 551
Great, I'll get tighten so. Was afraid to go too mad. Thanks for the tip on the front bracket. Just fitting fitting now 😁
Thanks for quick reply Shane |
