Home > Technical > Seat boxes - any reason not to replace with ally?
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
Is there any reason not to replace the steel battery and tool boxes with aluminium ones from the likes of YRM? Do they offer anything in terms of strength to the seat box assembly as a whole other than to provide rigidity?
I have a pair in the pile awaiting blasting, welding and galvanising but am drawn to the ally replacements to save time/hassle/weight.
Edit - If I do go down the ally route, any other worthwhile mods whilst I'm there? Deeper toolbox? 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #940562 1st Feb 2022 7:55pm
Bluest
They are probably fine, but there is quite a bit of weight in/on the seat boxes. Aluminium can be prone to fatigue failure and cracking, especially if subject to a lot of vibration. So, a road based truck would be less of a worry than an off roader or expedition rig. 2007 110 TDCi Station Wagon XS
Post #940564 1st Feb 2022 8:03pm
Shroppy
Good point! Though I suppose you could argue that the same can be said for the main shell of the seat and the rivets joining it to the steel boxes. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #940586 1st Feb 2022 9:43pm
Dinnu
Should not happen... but aluminium is much more reactive to acids than steel is. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #940590 1st Feb 2022 10:09pm
Shroppy
Good point Dinnu, think I may just stick with the steel ones after all! 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #940609 2nd Feb 2022 9:16am
Dinnu
I galvanized mine.. although zinc is even more reactive to acid spills than aluminium 😳
But I will give it several coats of paint before it is riveted to the seat box. Paint resist acid very well. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #940610 2nd Feb 2022 9:21am
Julie
Re: Seat boxes - any reason not to replace with ally?
Thinking about accélération in a car crash...
Post #942105 11th Feb 2022 9:36pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
If you have a car crash in a Defender I think the battery is not your biggest worry. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #942216 12th Feb 2022 6:57pm
Julie
The battery probably not, but my seat being screwed on an aluminium box - I'd carefully verify these connections
Post #942221 12th Feb 2022 7:16pm
roel
I don't think there is much steel in your seatbox. Roel
Post #942222 12th Feb 2022 7:24pm
donmacn
Not disputing any of the points above, but I put in a YRM metals allu seat box ages ago. I’d have to check, but I think it’s easily over 10 years. It is painted, inside and out. So far, I can’t see any downsides.
In the event of a crash, I think I’d rather the 3mm alu plate, solidly bonded and riveted together, compared to a rusty old steel box of indeterminate remaining strength.
I had to do mine, as the original box was literally disappearing, but I’d have no great hesitation in doing the same thing again. In fact I’m doing just that with a friend’s rebuild just now.
But if you do take the steel out and get it galvanised, make sure to put a good physical barrier between the two metals on reassembly. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #942223 12th Feb 2022 7:55pm
