![]() | Home > Technical > Seat boxes - any reason not to replace with ally? |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 878 ![]() ![]() ![]() |
Is there any reason not to replace the steel battery and tool boxes with aluminium ones from the likes of YRM? Do they offer anything in terms of strength to the seat box assembly as a whole other than to provide rigidity?
I have a pair in the pile awaiting blasting, welding and galvanising but am drawn to the ally replacements to save time/hassle/weight. Edit - If I do go down the ally route, any other worthwhile mods whilst I'm there? Deeper toolbox? 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
Good point! Though I suppose you could argue that the same can be said for the main shell of the seat and the rivets joining it to the steel boxes. 1985 127 V8 Build Thread
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3588 ![]() ![]() ![]() |
Should not happen... but aluminium is much more reactive to acids than steel is. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Good point Dinnu, think I may just stick with the steel ones after all! 1985 127 V8 Build Thread
I galvanized mine.. although zinc is even more reactive to acid spills than aluminium 😳
But I will give it several coats of paint before it is riveted to the seat box. Paint resist acid very well. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 588 ![]() ![]() ![]() |
Thinking about accélération in a car crash... |
If you have a car crash in a Defender I think the battery is not your biggest worry. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
The battery probably not, but my seat being screwed on an aluminium box - I'd carefully verify these connections
I don't think there is much steel in your seatbox. Roel
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1893 ![]() ![]() |
Not disputing any of the points above, but I put in a YRM metals allu seat box ages ago. I’d have to check, but I think it’s easily over 10 years. It is painted, inside and out. So far, I can’t see any downsides.
In the event of a crash, I think I’d rather the 3mm alu plate, solidly bonded and riveted together, compared to a rusty old steel box of indeterminate remaining strength. I had to do mine, as the original box was literally disappearing, but I’d have no great hesitation in doing the same thing again. In fact I’m doing just that with a friend’s rebuild just now. But if you do take the steel out and get it galvanised, make sure to put a good physical barrier between the two metals on reassembly. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
