![]() | Home > Puma (Tdci) > Think my rear discs needed a change |
Iktank Member Since: 08 Nov 2014 Location: Porthcawl Posts: 239 ![]() ![]() ![]() |
Though it was about time I changed the rear discs, pedal was continually pulsating on braking, got 48,000miles out of them so cant complain and 2years worth of advisories
![]() ![]() Click image to enlarge |
Paul55 Member Since: 03 Feb 2009 Location: Somewhere in my head! Posts: 514 ![]() ![]() ![]() |
I think your right, are you putting LOF ones on next?
Paul Cogito ergo sum |
Interestingly in many African countries you've got at least another 40k miles of use out of that disc ![]() They must have made a noise under braking, right... |
Got Brembo discs and pads for £74 Can’t believe how long it took me to do on the drive one side at a time - 5hrs in all Glad I did as bearings needed re-greasing 😁👍 Last edited by Iktank on 29th Jan 2022 7:05am. Edited 2 times in total |
Yeh we’re grinding, causing pedal to judder, ripped a few chunks of the pad 🥺🙈 |
