Home > Maintenance & Modifications > X Tech to Standard Grille Conversion
DC.
United Kingdom 2012 Defender 90 Puma 2.2 X-Tech LE Orkney Grey
Hi guys. First time posting, but long time LR owner. I've just purchased my second X Tech a 2.2 90 SW in Orkney Grey after previously owning a 2.4 Zermatt Silver 90 SW, when I lived in Australia. I also have a Series 3.
Potentially controversial opinion, but I've always found the front end on the X Tech a bit too 'pouty' for my likings and I want to switch the grille and headlight setup to a standard setup. I know it is a limited edition, but it can be changed back. Wondering if many people have changed an SVX front to standard?
Standard Grille & Headlight Surrounds
Air Con Radiator Grille Surround
Sidelights
Indicators
Fixings
Is there anything I am missing? I whipped most of the parts off yesterday to have a look. It felt like the radiator grille surround should have some kind of lower bracket / bracing as it only seems to screw into the 4 holes at the top. The SVX grille has 2 lower bolts into the headlight brackets.
The radiator grille surround I ordered does not fit, it's about 5-10mm too wide and so does not sit in, plus the mounting holes are all a bit off. Any recommendations / links to decent quality ones would be appreciated. There are so many reproduction ones out there, but many not in stock...
Thanks in advance.
Darren
Post #933712 15th Dec 2021 7:06pm
The standard A/C grill surround is fixed at the lower sides to two brackets that are bolted to the inner faces of the wings:
For what it's worth, I share your opinion of the X Tech grill Laughing Darren
Post #933725 15th Dec 2021 8:21pm
DC.
Lovely- thanks mate. Did not notice those, so I will whizz the fugly grille off and have another look.
Post #933773 15th Dec 2021 11:50pm
I can't offer fitting advice, I'm afraid, but I completely agree with your opinion of the hideous SVX grille! What were they thinking when they stuck that monstrosity on the front?
It will look much better when you've changed it. Thumbs Up
Post #933796 16th Dec 2021 9:31am
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
As above, horrid thing that svx grille
Let's see the before and after please Very Happy
Post #933812 16th Dec 2021 11:37am
L110CDL
Agree with the above comments Thumbs Up Clayton.
Keeper.
Post #934058 17th Dec 2021 10:02pm
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
I've come to defenders fairly late.
Had an old bitsa series 3, but not followed defenders in any detail other than being aware of the the general 90's, 110's, 130's etc, along with step changes in running gear e.g. tdi, td5 and the post 07 puma tdci..
So just wanted to say that, from reading this thread, I'm staggered to find out that the hideous front on that is a genuine LR design.. What were they thinking! yuk!
Fully supportive of your putting something better on there! good luck, and look forward to some 'after' pics.
Post #934064 17th Dec 2021 10:26pm
