Home > Maintenance & Modifications > Puma front timing case seal |
groky87 Member Since: 23 Feb 2021 Location: county durham Posts: 31 |
I always used Wynns black gasket maker its good stuff. Be sure its not coming g from the pump timing access panel or tge bottom crank seal first and if you buy a new timing casing these no longer come with a crank seal.
2nd Dec 2021 2:06am |
TC909 Member Since: 27 Jul 2021 Location: Lincolnshire Posts: 34 |
Click image to enlarge Rubbish photo, but it appears to be bottom left. Need to clean it off and see where its really coming from. [/img] |
2nd Dec 2021 9:09am |
I would say that is coming for the front crank seal easy job to fix i think an oe seal from Ford is £35-40
2nd Dec 2021 8:57pm |
