Home > Maintenance & Modifications > Puma front timing case seal
TC909
Front timing case seal appears to be weeping on my Puma.
Looks like a fairly common issue, is there anything to be aware of when replacing this?
I assume cover & seal- Are any gaskets better than others?
Post #931654 29th Nov 2021 9:50am
groky87
United Kingdom 2008 Defender 90 Other HT Santorini Black
I always used Wynns black gasket maker its good stuff. Be sure its not coming g from the pump timing access panel or tge bottom crank seal first and if you buy a new timing casing these no longer come with a crank seal.
Post #932123 2nd Dec 2021 2:06am
TC909
Rubbish photo, but it appears to be bottom left.
Need to clean it off and see where its really coming from.
[/img]
Post #932139 2nd Dec 2021 9:09am
groky87
I would say that is coming for the front crank seal easy job to fix i think an oe seal from Ford is £35-40
Post #932240 2nd Dec 2021 8:57pm
