Home > Puma (Tdci) > Nato Hitch attachment
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Flicking through the manual trying to find some info on max side slope, I came across the following;
“If a NATO hook or a Jaw and Pintle type towing accessory is to be fitted, do not attach them directly to the chassis rear cross member. It is essential that an adapter plate kit is also fitted.”
I guess this is just the spreader plate that goes between the hitch and the cross member?
Post #931171 25th Nov 2021 10:31pm
Ianh
Correct. KNK500030 .
Available from £11 upwards. I.e https://www.ebay.co.uk/itm/303328882760?ep...Sw6-5drCxY
Post #931193 25th Nov 2021 11:09pm
^^^ Not quite; that's the trailer breakaway attachment plate which was a modification for in service vehicles.
For the Td5/Puma defender LR say to use KNK100090K which is just a piece of angle iron that bolts under the crossmember (like the DB adjustable hitch has) and an extended version of the plate above that reaches down and is bolted to said angle iron.
Dead easy to make if you've got some thick steel kicking about.
Some google info here on it <-----
Post #931211 26th Nov 2021 7:48am
A receiver hitch works well too, and opens up a vast range of other attachment options.
Post #931218 26th Nov 2021 10:23am
You can even use your receiver hitch for your NATO hitch if the height work for you.
 Darren
Post #931346 26th Nov 2021 10:30pm
Vitesse
 2015 90 XS Santorini Black
Post #931865 30th Nov 2021 1:40pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
Interesting, where did you get the straight-through 2" receiver adaptor from? All the ones I have seen are drop plates. Or is it just a sawn-off and redrilled drop plate? ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #931970 1st Dec 2021 10:15am
^^ Mine came from Safari-Equip, via Brendan and Barbara at 4x4Overlander. I can't find it on the safari-Equip website, at present listed as out-of-stock on 4x4Overlander. In addition to the standard type, I had a special made as well on a longer shaft to fit my front receiver and clear the winch.
Although listed as designed for a NATO pintle it is of course drilled for standard BS Au24 four-bolt coupling (four holes 13.5mm diameter (or 33/64") at 85.75mm x 44.45mm (3.3/8" x 1.3/4") centres) so will mount any standard four-bolt hitch (for example a DB 5-tonne jaw and pin coupling).
https://www.4x4overlander.com/product/nato-hitch/
Post #931973 1st Dec 2021 10:28am
camelman
Safari Equip sell the receiver mounts for £168 on their website.
https://www.safari-equip.co.uk/shop/land-r...-td5-tdci/
The ad looks weird in that the photo is only of the the actual attachment and not the mounting part of the receiver.
I've just bought one however and it comes with all of the kit.
The nato hitch receiver without the drop plate can be found here: https://extreme4x4.co.uk/products/quickly-...o-receiver
As always you need to read the small print and depending on what you're fitting it to it might not be approved....
"Please note this 2″ receiver is not type approved towing equipment and is not sold as towing equipment"
Post #931976 1st Dec 2021 10:34am
I bought the NATO hitch adapter second hand but suspect that it's the Safari Equip one. I tried to buy new from 4x4 Overland but was told they were out of stock with no expected date, unfortunately.
Extreme 4x4 also list them but it's not clear if they have stock:
https://extreme4x4.co.uk/collections/qd-re...o-receiver
 Darren
Post #932008 1st Dec 2021 11:38am
camelman
extreme 4x4 have the 2 inch receiver adaptors for the nato hitches in the stock, just received a couple of them today Very Happy
Post #932898 8th Dec 2021 10:06pm
Cubflyer
United Kingdom 1994 Defender 90 300 Tdi SW Arles Blue
There are a number of plates on eBay, here's just one of them:
https://www.ebay.co.uk/itm/193003217873?ha...Sw5KVdCkrl
or
https://www.ebay.co.uk/itm/192557695924?ep...SwYeNbE9xm
John 2010 Defender 90 300Tdi CW (White/1994)
2021 Defender 90 300Tdi SW (Blue/1994)
Post #932914 8th Dec 2021 11:52pm
Avelingporter
For a sankey trailer you want the nato hitch in the centre of the crossmember. So using the 2" receiver hitch I have, I use a drop plate but turned upside down. About perfect to raise the nato hitch to sankey height.
Post #932945 9th Dec 2021 10:24am
pilsburypie
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
I’m thinking (just thinking!) of a penman trailer….. been reading that super long thread about you nato hitch perverts…. Disgusting!
Anyhow, if I were to try and join this band of disgraceful individuals, I need to extend my “spreader plate” (think?). Is it a case of buying a new one that incorporates the top threaded bolt holes in the cross member or is there an add on thing. Unfortunately it looks as though the current offering covers half the bottom holes. I could however doctor this if there is a simple add on. I do still need the lower tow ball for my regular trailer.
Looking at a few posts above, Vitesse has pretty much what I’m after. Is this purchased or a home made special?
Post #934543 21st Dec 2021 2:57pm
Harry.O
I've got a slightly different towing set-up to you but it had the same issue i.e. the lower holes on the crossmember were obscured by the tow bar hardware. I cut another piece of similar gauge steel to the existing tow bar bracketry and welded the new plate to said bracketry so that it covered the remaining holes on the crossmember which the NATO hitch would use.
This appears to be the same way as the picture that Vitesse posted above. The picture below probably explains it better than my description, albeit showing it before the upper plate was welded to the existing towing equipment. Nothing is welded to the rear crossmember itself though, should I want to remove it at a later date.
 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #934560 21st Dec 2021 5:51pm
