Home > Puma (Tdci) > Transit Oil Filter
buffalo4
Transit Oil Filter
Hi I have cross referenced Genuine Ford Oil Filters,
Seems a Transit Filter will Fit my 2.2 Puma
Genuine filter is half the price of a LR filter.
Anyone used a Transit filter ?
Thanks Ian
Post #928798 6th Nov 2021 5:31pm
Ianh
Are you talking about the LR030778 that fits in the plastic housing or the later metal canister screw on type fitted to later 2.2 pumas. What’s the ford part number you have as I’m interested to know as well.
Post #928801 6th Nov 2021 6:15pm
buffalo4
Hi its a later screw on cannister
LR058104
Ford Transit 2128722
Thanks Ian
Post #928804 6th Nov 2021 6:22pm
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
Transit one is decent. I don't quite understand Ford part numbers but the box reads:
2 128 722
EN: BK2Q-6714-BA WARNING.
This post may contain sarcasm.
Post #928805 6th Nov 2021 6:22pm
buffalo4
Here it is
Post #928806 6th Nov 2021 6:26pm
buffalo4
Nice one Thumbs Up
Post #928810 6th Nov 2021 6:53pm
Def90
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
Hi Ian
I think the correct Ford part number should be
BK2Q-6714-AA
This is it straight out of a LR box
BK2Q-6714-BA internals are a little different.
Post #928816 6th Nov 2021 8:00pm
buffalo4
Thank you for clarifying that
Post #928819 6th Nov 2021 8:07pm
macfrank
The holes look different but does it matter?
I have a MANN W 7050 for which all of the above part numbers (FOMOCO, FORD, LR) are given as cross reference.
https://catalog.mann-filter.com/EU/eng/cat...A0EEF521A9
Post #928825 6th Nov 2021 9:08pm
Iktank
Wales 2014 Defender 90 Puma 2.2 SW Corris Grey
I would also like to know - AA appears to have been superseded by the BA
since the 2.2 is a ford engine and the LR oils filter is a Ford oil filter I would assume the BA is just and improvement on the AA ?
As such I would assume the filter is fine to use in the Defender?
Post #931567 28th Nov 2021 3:51pm
buffalo4
I removed a BA previously fitted by Main Dealer and replaced with AA when carrying out oil change,
So both should be ok afaik
Post #931575 28th Nov 2021 5:00pm
