![]() | Home > Puma (Tdci) > Transit Oil Filter |
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2541
Are you talking about the LR030778 that fits in the plastic housing or the later metal canister screw on type fitted to later 2.2 pumas. What’s the ford part number you have as I’m interested to know as well.
| buffalo4 Member Since: 18 Apr 2020 Location: South Yorkshire Posts: 63
Hi its a later screw on cannister
LR058104 Ford Transit 2128722 Thanks Ian |
| Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3362
Transit one is decent. I don't quite understand Ford part numbers but the box reads:
2 128 722 EN: BK2Q-6714-BA WARNING. This post may contain sarcasm. Last edited by Zed on 6th Nov 2021 6:29pm. Edited 1 time in total |
Click image to enlarge Here it is Click image to enlarge |
Nice one
| Def90 Member Since: 17 Jan 2015 Location: Kent Posts: 268
Hi Ian
I think the correct Ford part number should be BK2Q-6714-AA This is it straight out of a LR box Click image to enlarge Click image to enlarge BK2Q-6714-BA internals are a little different. Click image to enlarge Click image to enlarge Click image to enlarge Last edited by Def90 on 6th Nov 2021 8:07pm. Edited 1 time in total |
Thank you for clarifying that
| macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1138
The holes look different but does it matter?
I have a MANN W 7050 for which all of the above part numbers (FOMOCO, FORD, LR) are given as cross reference. https://catalog.mann-filter.com/EU/eng/cat...A0EEF521A9 |
| Iktank Member Since: 08 Nov 2014 Location: Porthcawl Posts: 247
I would also like to know - AA appears to have been superseded by the BA
since the 2.2 is a ford engine and the LR oils filter is a Ford oil filter I would assume the BA is just and improvement on the AA ? As such I would assume the filter is fine to use in the Defender? |
I removed a BA previously fitted by Main Dealer and replaced with AA when carrying out oil change,
So both should be ok afaik |
