![]() | Home > Puma (Tdci) > 2009 Puma leaking water under the engine |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711 ![]() ![]() ![]() |
Water from aircon ? There is a rubber 'duck mouth' on the end of the aircon drain. It gets blocked so the water can't drain and builds up. When you park up the trapped water slowly finds its way out.
If it is this you are going to have to get under the vehicle and reach up above the front of the gearbox and unblock the duck mouth. Be prepared to get a wet arm. 130's have feeling's as well you know ![]() |
Rob2798 Member Since: 24 Oct 2021 Location: Leicester Posts: 6 ![]() ![]() ![]() |
Hi, thanks so much for your reply. It does look exactly like water from an aircon unit but mine doesn't have aircon unfortunately so it can't be that.
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
Water pump failed running down the chassis had this on mine a few years ago the plastic out let’s fail and new pump needed 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
Ah thanks. It only leaks for a few minutes after stopping. Does that sound right? Would the water be clear if it's the pump? Shouldn't it be coolant? The coolant level seems fine you see. Sorry for asking so many questions. Do you know if it's an easy job to fix?
You’ll struggle to see a different colour unless heavily mixed give it a taste if it’s sweet then prob coolant
New water pump will sort about an hours job hardest bit is bleeding back up Worth replacing vcv valve whilst your at it 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
Only other thing I can think would be heater matrix again would be coolant leaking failing that check your washer bottle but wouldn’t matter of running or not with that
No where else for water to come from 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
Thanks that's great advice. I collected some of the fluid in a jar and it was definitely clear and odourless. I'm over in Europe at the minute so I've not got a Haynes manual with me sadly but isn't the water pump on the left hand side of the engine as you look at it from the front? The leak is on the opposite side if so. Would it leak all the time or only after having driven the car do you know?
Thanks so much for all of this. I'm just worried about being stranded somewhere! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17936 ![]() ![]() ![]() |
The water pump is on the nearside of the engine, not the offside.
Ah great, that would make sense cheers
Can I ask why you think it's worth changing the VCV valve at the same time please?
Very occasionally I've had a problem where the engine loses power until I stop it and then restart. I had thought that it was a sticky EGR valve but it has done it twice since having the EGR valve deleted. Some people have suggested that it could be the VCV valve so it sounds like a great idea but I'm not sure whty it would be worth changing it at the same time as the water pump. |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 737 ![]() ![]() ![]() |
Could it be a blocked outlet on the air intake box for the heater. There is a rubber valve in the base which can become blocked with leaves and detritus. Worth checking.
^^ This. If you're not losing coolant or screen-washer fluid, and don't have a/c, there is not much else it can be.
