Home > Puma (Tdci) > 2009 Puma leaking water under the engine
Rob2798
United Kingdom 2009 Defender 110 Puma 2.4 CSW Zermatt Silver
Hi, Thanks for allowing me into the group. I have a quick question please. I've had my Defender for 2 leak free years. In the last few days I've noticed a small puddle of water forming on the ground under the engine on the front passenger side of the car after I've been driving it for maybe 20 minutes.
The water is clear and I'm fairly sure it isn't washer fluid as it has no odour and the washer bottle is full. Similarly, although I did find a single drop of coloured water on the chassis similar to coolant, the majority is absolutely clear and it can be seen running down the chassis from somewhere in the engine bay.
It looks like the sort of condensation that you get from aircon but mine is only a CSW with no aircon and it's never done it before. the only thing that has changed is that I recently had a Stage 1 remap and EGR delete carried out but I've covered 1000 miles since then and the car drives well and the temp seems fine.
Is this something that I should worry about or has anyone else seen anything similar?
I'd be really grateful for any suggestions especially because I'm over in Europe with it at the minute and I don't want to do anything that will cause me problems further down the line.
Thanks so much!
Post #927010 24th Oct 2021 10:22pm
AndrewS
Water from aircon ? There is a rubber 'duck mouth' on the end of the aircon drain. It gets blocked so the water can't drain and builds up. When you park up the trapped water slowly finds its way out.
If it is this you are going to have to get under the vehicle and reach up above the front of the gearbox and unblock the duck mouth. Be prepared to get a wet arm. 130's have feeling's as well you know Smile
Post #927012 24th Oct 2021 10:49pm
Rob2798
Hi, thanks so much for your reply. It does look exactly like water from an aircon unit but mine doesn't have aircon unfortunately so it can't be that.
Post #927013 24th Oct 2021 10:51pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Water pump failed running down the chassis had this on mine a few years ago the plastic out let’s fail and new pump needed 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #927018 24th Oct 2021 11:16pm
Rob2798
Ah thanks. It only leaks for a few minutes after stopping. Does that sound right? Would the water be clear if it's the pump? Shouldn't it be coolant? The coolant level seems fine you see. Sorry for asking so many questions. Do you know if it's an easy job to fix?
Post #927019 24th Oct 2021 11:21pm
pj2106
You’ll struggle to see a different colour unless heavily mixed give it a taste if it’s sweet then prob coolant
New water pump will sort about an hours job hardest bit is bleeding back up
Worth replacing vcv valve whilst your at it 2008 110 2.4 XS Utility (Hagrid)
Post #927020 24th Oct 2021 11:37pm
pj2106
Only other thing I can think would be heater matrix again would be coolant leaking failing that check your washer bottle but wouldn’t matter of running or not with that
No where else for water to come from 2008 110 2.4 XS Utility (Hagrid)
Post #927021 24th Oct 2021 11:38pm
Rob2798
Thanks that's great advice. I collected some of the fluid in a jar and it was definitely clear and odourless. I'm over in Europe at the minute so I've not got a Haynes manual with me sadly but isn't the water pump on the left hand side of the engine as you look at it from the front? The leak is on the opposite side if so. Would it leak all the time or only after having driven the car do you know?
Thanks so much for all of this. I'm just worried about being stranded somewhere!
Post #927022 24th Oct 2021 11:44pm
The water pump is on the nearside of the engine, not the offside.
Post #927023 24th Oct 2021 11:51pm
Rob2798
Ah great, that would make sense cheers
Post #927024 24th Oct 2021 11:52pm
Rob2798
Can I ask why you think it's worth changing the VCV valve at the same time please?
Very occasionally I've had a problem where the engine loses power until I stop it and then restart. I had thought that it was a sticky EGR valve but it has done it twice since having the EGR valve deleted. Some people have suggested that it could be the VCV valve so it sounds like a great idea but I'm not sure whty it would be worth changing it at the same time as the water pump.
Post #927025 25th Oct 2021 4:09am
Balvaig
Could it be a blocked outlet on the air intake box for the heater. There is a rubber valve in the base which can become blocked with leaves and detritus. Worth checking.
Post #927035 25th Oct 2021 9:35am
^^ This. If you're not losing coolant or screen-washer fluid, and don't have a/c, there is not much else it can be.
Post #927038 25th Oct 2021 9:52am
