![]() | Home > Tdi > HELLO and rear wiring loom |
| geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4410
Hello and welcome to the forum
Start with the easy one. The cable with 7 wires is likely to be the trailer wiring harness that someone has put crimp bullet connectors on. The extra cables you have are for a left hand drive Defender. LR just added the the extra wires to save on having a left and right hand wiring loom. The good news is that if you ever want to add extra reverse lights you can just use these connectors. |
| under_rover Member Since: 02 Apr 2013 Location: Yorkshire Posts: 153
This might help you
https://www.lrworkshop.com/wiring-looms/de...s-loom-110 Cheers Laurie 90 rebuild thread - https://www.defender2.net/forum/topic62909.html |
| Leolandy Member Since: 29 Sep 2021 Location: Rutland Posts: 2
cheers both !!!!
I thought i was going mad with all these spare connectors but that makes prefect sense. Just the wiring to go, cant be that bad / hard |
| Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2395
The other wires are probably for heated rear glass and rear wiper. The bunch of 7 is as geobloke has said, for towing electrics.
