![]() | Home > Maintenance & Modifications > Cruise control with max speed setting |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 895 ![]() ![]() |
I'm looking at the kits to add cruise control to my puma.
Before I take the plunge does anyone know of a kit that does cruise control but also like most modern cars allows you to set a max speed. I find on rental cars I just set this to 70 ( ![]() I doubt it's been made as a retrofit, but wanted to ask the forum. Cheers PCM |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 ![]() ![]() ![]() |
The CanM8 cruise control has this. Roaming around 🇳🇴🇨ðŸ‡
Def90 Member Since: 17 Jan 2015 Location: Kent Posts: 268 ![]() ![]() ![]() |
Hi PCM
I believe the John Gold cruise control system has a speed limiter function built into it but only for the puma defenders. Give Conrad Anderson a call they are very helpful. https://www.conrad-anderson.co.uk/products...se-control |
I just love this forum. Was going to spend more on an inferior system. Not any more.
Many many thanks. |
