Home > Maintenance & Modifications > Cruise control with max speed setting
PCM
I'm looking at the kits to add cruise control to my puma.
Before I take the plunge does anyone know of a kit that does cruise control but also like most modern cars allows you to set a max speed.
I find on rental cars I just set this to 70 ( Shocked ) and then the accelerator won't allow you to go more than this unless you floor it. It's arguable far better than cruise that is only good on empty roads and if you're not careful has a tendency to drive you straight into the back of the car in front.
I doubt it's been made as a retrofit, but wanted to ask the forum.
PCM
Post #920119 5th Sep 2021 7:41pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
The CanM8 cruise control has this. Roaming around 🇳🇴🇨🇭
Post #920124 5th Sep 2021 7:56pm
Def90
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
Hi PCM
I believe the John Gold cruise control system has a speed limiter function built into it but only for the puma defenders.
Give Conrad Anderson a call they are very helpful.
https://www.conrad-anderson.co.uk/products...se-control
Post #920132 5th Sep 2021 8:25pm
PCM
I just love this forum. Was going to spend more on an inferior system. Not any more.
Many many thanks.
Post #920154 6th Sep 2021 5:43am
