Home > Maintenance & Modifications > Repair Ideas On Split Door Skin |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10513 |
Yes i have used JB weld and this is the result
Click image to enlarge so fixed it this way Click image to enlarge 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
3rd Sep 2021 9:34pm |
karlp606 Member Since: 19 Aug 2021 Location: Hull Posts: 295 |
Did you drill the holes originally on the 1st pic or are there standard in those locations?
3rd Sep 2021 9:35pm |
The bolt on the left is there already, i only drilled the hole on the right 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
3rd Sep 2021 9:45pm |
Just a bit scared of drilling mine as the glass is directly behind that left hand side of the skin that's split. Think I may MIG weld it?
8th Sep 2021 9:28pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3208 |
If you have a mig welder, then welding it is the best option.
I got a very cheap gas less mig welder, but got a very expensive wire for it (cost of the wire is 50% of the machine), cause the wire that comes with the machine is crap. Was pleased with the results when I replaced the bottom sections. Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
8th Sep 2021 9:40pm |
Yeh been looking at a few MIGs on Halfords and Screwfix, look a safe bet for under £100 and will always come in handy with a defender lol
8th Sep 2021 9:41pm |
Welding is a better way to go but as i don't know how to weld i went down the route i did 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
8th Sep 2021 9:48pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1758 |
MIG welding for sure if you have the capability. Personally I wouldn't bother with a gasless mig though.
8th Sep 2021 9:53pm |
Got mine from Lidl (Parkside). I also modified it for DC current as I could not weld with the wire that came with the package. But also DC, did not make a great improvement. Then got the wire from Japan... day night difference in welding quality.
Another repair with the cheap mig, sorry no picture after grinding.... but I think it already paid itself a few times. Click image to enlarge Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
8th Sep 2021 9:56pm |
I agree that CO2 Mig are better, and perhaps easier to use, does not leave flux residue, and very importantly solid wire used with CO2 does not give the toxic fumes that the gasless mig wire does. Only use gasless migs in well ventilated areas.
For me I just could not justify spending 3-4x the price I could get the gas less mig, as I do not have much use for it. Here is another shot of a weld from my gasless mig. I think it is not bad barring the spatter. So can still give good results for little money. If you are using mig more often, then the cost of the gasless (flux core) wire will become prohibitive. Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
8th Sep 2021 10:10pm |
Thanks guys, think I will go down the gasless route as I'll probably use it few and far between but it will always come in handy.
I do have good soldering skills so hopefully I can transfer these to welding lol. |
9th Sep 2021 9:40am |
Watch a few videos.
For me the gasless worked after: 1. Got the best quality flux core wire (I think I use 0.90mm). 2. Use the gasless mig as if it was a stick welder. The direction of welding relative to the angle of the torch is same as in stick welding (opposite to CO2 welding). Once I figured the 2 above, then it was relatively easy. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
9th Sep 2021 10:37am |
