Home > Maintenance & Modifications > Repair Ideas On Split Door Skin
karlp606
United Kingdom 1997 Defender 90 300 Tdi CSW Firenze Red
So after taking my door cards off Ive noticed the old door skin split near the door locking latch area ;
After looking at a few options has anyone used JB Weld on a similar door skin split?
I was looking at using a plate between the split and screwing it together but seeing JB Weld was thinking this would be easier, plus I don't want to be really drilling through already weakened skin.
Post #919862 3rd Sep 2021 9:13pm
L110CDL
Yes i have used JB weld and this is the result Rolling Eyes
so fixed it this way
Thumbs Up Clayton.
Keeper.
Post #919869 3rd Sep 2021 9:34pm
karlp606
Did you drill the holes originally on the 1st pic or are there standard in those locations?
Post #919871 3rd Sep 2021 9:35pm
L110CDL
The bolt on the left is there already, i only drilled the hole on the right Thumbs Up Clayton.
Keeper.
Post #919876 3rd Sep 2021 9:45pm
karlp606
Just a bit scared of drilling mine as the glass is directly behind that left hand side of the skin that's split. Think I may MIG weld it?
Post #920605 8th Sep 2021 9:28pm
Dinnu
If you have a mig welder, then welding it is the best option.
I got a very cheap gas less mig welder, but got a very expensive wire for it (cost of the wire is 50% of the machine), cause the wire that comes with the machine is crap. Was pleased with the results when I replaced the bottom sections.
 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #920607 8th Sep 2021 9:40pm
karlp606
Yeh been looking at a few MIGs on Halfords and Screwfix, look a safe bet for under £100 and will always come in handy with a defender lol Laughing
Post #920608 8th Sep 2021 9:41pm
L110CDL
Welding is a better way to go but as i don't know how to weld i went down the route i did Very Happy Clayton.
Keeper.
Post #920613 8th Sep 2021 9:48pm
miker
MIG welding for sure if you have the capability. Personally I wouldn't bother with a gasless mig though.
Post #920616 8th Sep 2021 9:53pm
Dinnu
Got mine from Lidl (Parkside). I also modified it for DC current as I could not weld with the wire that came with the package. But also DC, did not make a great improvement. Then got the wire from Japan... day night difference in welding quality.
Another repair with the cheap mig, sorry no picture after grinding.... but I think it already paid itself a few times.
Post #920617 8th Sep 2021 9:56pm
Dinnu
I agree that CO2 Mig are better, and perhaps easier to use, does not leave flux residue, and very importantly solid wire used with CO2 does not give the toxic fumes that the gasless mig wire does. Only use gasless migs in well ventilated areas.
For me I just could not justify spending 3-4x the price I could get the gas less mig, as I do not have much use for it. Here is another shot of a weld from my gasless mig. I think it is not bad barring the spatter. So can still give good results for little money. If you are using mig more often, then the cost of the gasless (flux core) wire will become prohibitive.
Post #920619 8th Sep 2021 10:10pm
karlp606
Thanks guys, think I will go down the gasless route as I'll probably use it few and far between but it will always come in handy.
I do have good soldering skills so hopefully I can transfer these to welding lol.
Post #920659 9th Sep 2021 9:40am
Dinnu
Watch a few videos.
For me the gasless worked after:
1. Got the best quality flux core wire (I think I use 0.90mm).
2. Use the gasless mig as if it was a stick welder. The direction of welding relative to the angle of the torch is same as in stick welding (opposite to CO2 welding).
Once I figured the 2 above, then it was relatively easy. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #920666 9th Sep 2021 10:37am
