Home > Puma (Tdci) > Bulkhead mat - how is it attached?
Gasket
Hi folks.
Re: the moulded bulkhead/footwell mat fitted to the puma (part number LR066463).
I’m going to be removing mine to fit dynamat behind. Aside from the two corner strips that pin it to the door pillars, is the mat attached in any other way? I’m thinking adhesive or carpet tape.
Mine has actually bowed out slightly around the pedals so will need something to secure it back to the bulkhead.
Thanks.
Post #919276 31st Aug 2021 12:58am
Oldowner
As well as the two plates on the door pillars there are two horizontal folded plates screwed to the bulkhead that attempt to support the upper edge of the matting. The matting always seems to bow around the pedals.
Post #919278 31st Aug 2021 5:27am
