- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Gasket
Bulkhead mat - how is it attached? | |
Hi folks.
Re: the moulded bulkhead/footwell mat fitted to the puma (part number LR066463).
I’m going to be removing mine to fit dynamat behind. Aside from the two corner strips that pin it to the door pillars, is the mat attached in any other way? I’m thinking adhesive or carpet tape.
Mine has actually bowed out slightly around the pedals so will need something to secure it back to the bulkhead.
Thanks.
31st Aug 2021 12:58am |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
