Home > Technical > Discovery 200tdi transplant, wiring issues
rangerslandy
United States 1984 Defender 90 200 Tdi SW Orkney Grey
Hi everyone,
First time poster here and hoping I can draw on your knowledge and experience!
I've recently put a 200tdi from a Disco into my 1984 90. I've been speaking to autosparks to try and find the right wiring harness/loom to connect from the engine into my dash but I'm really struggling to find anything that uses this connector.
Any ideas?
Cheers!
Post #915530 4th Aug 2021 10:31pm
Dinnu
Pictures in OPs gallery.
1984 should have the multi bullet connector type (if that is the right name for the connector). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #915567 5th Aug 2021 7:55am
dorsetsmith
Is plug and wiring part of your Discovery 200tdi engine or part of the 1984 defender 90 ?
using wire colour at the plug and wiring PDF see below and work it out
https://www.defender2.net/gallery/albums/u...le0015.PDF
working left to right
WR white / red ----- NY Brown/ yellow ------ BW black/white ------- WN white / brown ?
Post #915574 5th Aug 2021 8:58am
htb2
Wales
Whenever I have done it I have always used the Landrover multipin block, cut the appropriate wires about 6-10" engine side of it and spliced it to the discovery engine harness as required with soldered connection, heat shrink and the ribbed wire protector to support it. Dont cut all the wires the same length as all joints will be in the same place, space them about 1-2" apart to give a neater/smoother finish.
Post #915582 5th Aug 2021 9:57am
