![]() | Home > Technical > Discovery 200tdi transplant, wiring issues |
rangerslandy Member Since: 04 Aug 2021 Location: Lone Tree, Colorado Posts: 1 ![]() ![]() ![]() |
Hi everyone,
First time poster here and hoping I can draw on your knowledge and experience! I've recently put a 200tdi from a Disco into my 1984 90. I've been speaking to autosparks to try and find the right wiring harness/loom to connect from the engine into my dash but I'm really struggling to find anything that uses this connector. Any ideas? Cheers! |
Is plug and wiring part of your Discovery 200tdi engine or part of the 1984 defender 90 ?
using wire colour at the plug and wiring PDF see below and work it out https://www.defender2.net/gallery/albums/u...le0015.PDF ![]() ![]() Click image to enlarge working left to right WR white / red ----- NY Brown/ yellow ------ BW black/white ------- WN white / brown ? Last edited by dorsetsmith on 5th Aug 2021 12:14pm. Edited 7 times in total |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 548 ![]() ![]() |
Whenever I have done it I have always used the Landrover multipin block, cut the appropriate wires about 6-10" engine side of it and spliced it to the discovery engine harness as required with soldered connection, heat shrink and the ribbed wire protector to support it. Dont cut all the wires the same length as all joints will be in the same place, space them about 1-2" apart to give a neater/smoother finish.
