Home > Maintenance & Modifications > TDCI Immobiliser/Key program
DiscoStu
United Kingdom 2013 Defender 110 Puma 2.2 SW Santorini Black
Hello all. Can anyone recommend anyone to reprogram keys to the immobiliser in North Shrops please? Mobile ideally..... My Disco 'best bits'
Defender 110 XS CSW 2013
Post #913174 20th Jul 2021 7:26am
Ianh
Sorry for being pedantic, but it’s the fobs that need programming not the keys. If yours is a 2.2 2013 defender it will likely have the old fobs, not the newer ones with the chrome strip on the side, unless at some point the ALM module was replaced in which case you will have the latter fobs.
If anyone on here has a nanocom for a 2.4 / 2.2 Puma and they are near by they can do it quickly for you. If they have the latest download from nanocom then this should not be an issue even if you have an ALM not 10AS alarm ECU.
A local indi will also likely be able to do it at a reasonable price.
Ps are you sure they need reprogramming, not a re sync, as a re sync you can do yourself. I.e outside of your vehicle with doors closed , leave a window open, press lock button 4 to 5 times in succession, then press the unlock button.
Post #913244 20th Jul 2021 5:11pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Re: TDCI Immobiliser/Key program
These guys are usually helpful, based in Oswestry, and may be able to point you in the right direction - https://www.mcdonald4x4.co.uk/
Good luck Just because you're offended doesn't mean you're right.
Post #913245 20th Jul 2021 5:16pm
DiscoStu
Thank you 👍 My Disco 'best bits'
Post #913538 22nd Jul 2021 9:22am
DiscoStu
Apology accepted Very Happy
She’s sat for nearly 2 years with flat battery and flat fobs, I can’t get it to re-sync whatever I do. Thanks for the info on the Nanocom Thumbs Up My Disco 'best bits'
Post #913539 22nd Jul 2021 9:28am
