![]() | Home > Technical > Reverse switch loom connector location |
rherl Member Since: 22 Mar 2012 Location: Utah Posts: 8 ![]() ![]() |
I think I found the answer. Looks like it comes off from the engine harness and not the bulkhead loom. Looks like I'll need to make my own.
I'm not sure if this helps but here's a picture of the reverse light switch connector on my 13MY Defender, which I took when I had to replace a failed switch. None of the colours match what you've suggested, I'm afraid.
![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6705 ![]() ![]() ![]() |
On a 2.4 it's on the engine loom, on a 2.2 it is on the main bulkhead loom.
Thanks for the help. Martin, I ordered 2 of your TD5 to Td4 adapters. I will use them to make the connection back to the fuse box and to the reverse lamp.
