![]() | Home > General & Technical (L663) > S vs SE |
Ryderoo Member Since: 28 Aug 2015 Location: South Oxfordshire Posts: 1666 ![]() ![]() ![]() |
https://www.landrover.co.uk/Images/Land-Ro...1558968701
Here’s the brochure and spec guide, this should help Cheers Simon I can explain it to you, but I can't understand it for you 1990 110 TD5 county, my first Land Rover - gone 2012 Discovery 4 XS SDV6 - gone 2014 Discovery 4 XS SDV6 - gone 2015 Evoque SD4 dynamic - Wife’s - gone 2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone 2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24 2021 Defender S D250 Santorini Black 110 HT - gone March 24 2023 Evoque P300e SE wife’s current vehicle |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 707 ![]() ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge 2008 Defender 110 XS SW - M57N2 / 8HP70X |
SN Member Since: 30 Jun 2007 Location: SK6 Posts: 729 ![]() |
Specs seem to have changed for MY22 but one thing that hasn't is the head/fog lights - you don't really want the white plastic circle faking the LED DRL and you should have fog lights on a £50k+ car - on my MY21 S it 'was' only a £500 upgrade to fix that, I don't know on MY22 but on MY21 you could save a packet on the D200 engine instead of having to pay the a lot extra for the D250 minimum at SE Steve N | 21MY Defender ![]() ![]() ![]() |
I chose S spec for my D250 110 hard top. Spec was more than adequate, I was purchasing on a budget as I have some additions post purchase.
The matrix leds with fogs would have been be a nice addition. I’m sure the standard led lights will give plenty of illumination at night. Don’t get me wrong, the matrix leds do look cool. Cheers Simon I can explain it to you, but I can't understand it for you 1990 110 TD5 county, my first Land Rover - gone 2012 Discovery 4 XS SDV6 - gone 2014 Discovery 4 XS SDV6 - gone 2015 Evoque SD4 dynamic - Wife’s - gone 2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone 2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24 2021 Defender S D250 Santorini Black 110 HT - gone March 24 2023 Evoque P300e SE wife’s current vehicle |
mf7480 Member Since: 14 Jun 2021 Location: Gloucestershire Posts: 94 ![]() |
Same situation here. Are the additions rear seats?
Kubrick1978 Member Since: 01 May 2021 Location: Midlands Posts: 101 ![]() ![]() |
I went for the S spec and then added the signature lights and Meriden sound system. Didn't really need anything else (premium cabin lighting etc.) - but then I also went after some HSE bits and pieces, like the panoramic sun roof etc. I just looked at all the options and selected what I wanted - then tested what the best value was between the different trims. I started off with the base spec and worked my way upwards. In the end I settled on the S spec. But based on the new configurator I would need to go for an SE to get the D200 that I ordered now.
Oldyellar Member Since: 04 Sep 2015 Location: Central Posts: 419 ![]() ![]() ![]() |
Thanks guys alot to take in with them it's not for me it's for Dad he has a 2.0l 110 200 S atm looking at a new D250 for March 22.
Here is what he has came up with https://build.landrover/4DD01111 |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1448 ![]() ![]() ![]() |
Yep the D200 SE is nearly £8k cheaper than a D250 SE ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
No not seats, I did have seats put in a D4 commercial I used to run, which were great. I have purchased this Defender to actually run as a van so need the space. I did think about seats but they would be down all the time. If I need to carry more people I’ll use the D5. Cheers Simon I can explain it to you, but I can't understand it for you 1990 110 TD5 county, my first Land Rover - gone 2012 Discovery 4 XS SDV6 - gone 2014 Discovery 4 XS SDV6 - gone 2015 Evoque SD4 dynamic - Wife’s - gone 2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone 2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24 2021 Defender S D250 Santorini Black 110 HT - gone March 24 2023 Evoque P300e SE wife’s current vehicle |
