Home > General & Technical (L663) > S vs SE |
Ryderoo Member Since: 28 Aug 2015 Location: South Bucks Posts: 1656 |
https://www.landrover.co.uk/Images/Land-Ro...1558968701
Here’s the brochure and spec guide, this should help Cheers Simon I can explain it to you, but I can't understand it for you 2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone 2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24 2021 Defender S D250 Santorini Black 110 Hard Top on the drive - gone March 24 |
28th Jun 2021 7:29am |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 695 |
Click image to enlarge Click image to enlarge 2008 Defender 110 XS SW - M57N2 / 6HP28X |
28th Jun 2021 9:52am |
SN Member Since: 30 Jun 2007 Location: SK6 Posts: 729 |
Specs seem to have changed for MY22 but one thing that hasn't is the head/fog lights - you don't really want the white plastic circle faking the LED DRL and you should have fog lights on a £50k+ car - on my MY21 S it 'was' only a £500 upgrade to fix that, I don't know on MY22 but on MY21 you could save a packet on the D200 engine instead of having to pay the a lot extra for the D250 minimum at SE Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history) |
28th Jun 2021 11:12am |
I chose S spec for my D250 110 hard top. Spec was more than adequate, I was purchasing on a budget as I have some additions post purchase.
The matrix leds with fogs would have been be a nice addition. I’m sure the standard led lights will give plenty of illumination at night. Don’t get me wrong, the matrix leds do look cool. Cheers Simon I can explain it to you, but I can't understand it for you 2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone 2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24 2021 Defender S D250 Santorini Black 110 Hard Top on the drive - gone March 24 |
28th Jun 2021 1:07pm |
mf7480 Member Since: 14 Jun 2021 Location: Gloucestershire Posts: 86 |
Same situation here. Are the additions rear seats?
28th Jun 2021 2:00pm |
Kubrick1978 Member Since: 01 May 2021 Location: Midlands Posts: 101 |
I went for the S spec and then added the signature lights and Meriden sound system. Didn't really need anything else (premium cabin lighting etc.) - but then I also went after some HSE bits and pieces, like the panoramic sun roof etc. I just looked at all the options and selected what I wanted - then tested what the best value was between the different trims. I started off with the base spec and worked my way upwards. In the end I settled on the S spec. But based on the new configurator I would need to go for an SE to get the D200 that I ordered now.
28th Jun 2021 9:00pm |
Oldyellar Member Since: 04 Sep 2015 Location: Central Posts: 338 |
Thanks guys alot to take in with them it's not for me it's for Dad he has a 2.0l 110 200 S atm looking at a new D250 for March 22.
Here is what he has came up with https://build.landrover/4DD01111 |
28th Jun 2021 9:30pm |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1331 |
Yep the D200 SE is nearly £8k cheaper than a D250 SE That's why I've chosen the D200 SE Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
28th Jun 2021 11:26pm |
No not seats, I did have seats put in a D4 commercial I used to run, which were great. I have purchased this Defender to actually run as a van so need the space. I did think about seats but they would be down all the time. If I need to carry more people I’ll use the D5. Cheers Simon I can explain it to you, but I can't understand it for you 2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone 2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24 2021 Defender S D250 Santorini Black 110 Hard Top on the drive - gone March 24 |
29th Jun 2021 5:09am |
