Home > Puma (Tdci) > Is there a Ford equivalent for LR032066 (2015-Puma 2.2) ?
Gleo
Isle Of Man
Hi
Having difficulty getting 8 x LR032066 crankshaft rear oil seal M6
Flanged bolts in theUK or Ireland at the moment to allow me replace my 2015 2.2 puma crank shaft rear oil seal.
Wondering if their might be a Ford transit equivalent part number for these M6 bolts/screws, as I tried Paddocks etc and they seem.to be difficult to get at the moment?
Thanks in advance
Post #907983 15th Jun 2021 6:29pm
M6 x 10mm flange head (or serrated flange head) bolts should be available from almost any fastener supplier, with no need to use LR parts. There will be a Ford equivalent but I am afraid I don't know the part number.
Post #907995 15th Jun 2021 7:01pm
Gleo
Isle Of Man
Thanks Blackwolf for the reply. Reckoned so myself, as there is no specific pressure on these bolts they are just holding in the crankshaft rear oil seal.
Post #907999 15th Jun 2021 7:12pm
Dinnu
If they are 10mm long.
https://www.paddockspares.com/fs106101l-flange-screw.html
There was a thread a short while ago, and managed to keep the FS number in my normally volatile memory, as it has been very useful.
If you want longer:
https://www.paddockspares.com/catalogsearch/result/?q=FS106
Please verify if the bolts are really x10mm long, as the below link says x10, but the picture shows x16mm
https://www.brit-car.co.uk/product.php/188...er_2007_on 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #908000 15th Jun 2021 7:13pm
Gleo
Isle Of Man
M6 x 14mm is what's in the puma 2.2 for my MY15 model but various sites quote the official LR part number as different lengths.
Think at this stage I'll just re-use the existing ones as they seem to be fine despite the workshop manual suggesting they should be replaced as new. Fair enough for flywheel bolts to renew them as new, but the crankshaft rear oil seal bolts don't have had any stress on them
Post #908020 15th Jun 2021 8:49pm
They're not stretch bolts, so no need to renew them.
Post #908052 15th Jun 2021 10:51pm
Gleo
Isle Of Man
Found the Ford puma transit equivalents this morning and half the price that they are at a Land Rover dealer. The Ford part number is 1 746 201, packet is marked made in Poland, as is the LR version, so probably originating
from the same factory.
Post #908164 16th Jun 2021 4:17pm
dorsetsmith
Post #908168 16th Jun 2021 4:37pm
