![]() | Home > Puma (Tdci) > Is there a Ford equivalent for LR032066 (2015-Puma 2.2) ? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17876 ![]() ![]() ![]() |
M6 x 10mm flange head (or serrated flange head) bolts should be available from almost any fastener supplier, with no need to use LR parts. There will be a Ford equivalent but I am afraid I don't know the part number.
Gleo Member Since: 01 Mar 2016 Location: Mayo Posts: 43 ![]() ![]() |
Thanks Blackwolf for the reply. Reckoned so myself, as there is no specific pressure on these bolts they are just holding in the crankshaft rear oil seal.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3588 ![]() ![]() ![]() |
If they are 10mm long.
https://www.paddockspares.com/fs106101l-flange-screw.html There was a thread a short while ago, and managed to keep the FS number in my normally volatile memory, as it has been very useful. If you want longer: https://www.paddockspares.com/catalogsearch/result/?q=FS106 Please verify if the bolts are really x10mm long, as the below link says x10, but the picture shows x16mm https://www.brit-car.co.uk/product.php/188...er_2007_on 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
![]() ![]() Click image to enlarge M6 x 14mm is what's in the puma 2.2 for my MY15 model but various sites quote the official LR part number as different lengths. Think at this stage I'll just re-use the existing ones as they seem to be fine despite the workshop manual suggesting they should be replaced as new. Fair enough for flywheel bolts to renew them as new, but the crankshaft rear oil seal bolts don't have had any stress on them |
They're not stretch bolts, so no need to renew them.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Found the Ford puma transit equivalents this morning and half the price that they are at a Land Rover dealer. The Ford part number is 1 746 201, packet is marked made in Poland, as is the LR version, so probably originating ![]() Click image to enlarge from the same factory. |
