![]() | Home > Maintenance & Modifications > Need help with cruise control wiring – 2.4l |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4289 ![]() ![]() ![]() |
What brand is the cruise control? I have a Mobile Centre one which is a rebranded LiteOn Unit. If yours is the same I could scan my wiring instructions for you in case that helps. 2007 110 TDCi Station Wagon XS
Donleguano Member Since: 13 Jan 2018 Location: Zurich Posts: 8 ![]() ![]() ![]() |
Thx, but its not the same i think.
Its one from Britpart, manufacturer is from Denmark. The Name of the Cruise Control is: E-Cruise Control. Several other shops sell this, also Nakatanenga from Germany... Thx for the Help! |
Hi Guys,
now everything is clear – thx anyway for the help! Have an other question. Has anyone crimped the cables instead of soldering? thx |
I almost always crimp rather than solder. 2007 110 TDCi Station Wagon XS
PCM Member Since: 25 Jan 2019 Location: North East Posts: 895 ![]() ![]() |
See below for step by step images, It's a 2-3 hour job.
https://www.autoexpress.co.uk/land-rover/1...u-defender |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17852 ![]() ![]() ![]() |
There are several fairly compelling engineering reasons why crimping is more satisfactory and more durable than soldering. |
Thx guys for your help
![]() I will crimp for sure then. Im not very talented in soldering ![]() And thx for the step by step guide! This helps a lot… the only thing there which does not show is the yellow/blue cable for the 2.4 But bith go into the red with fuse ![]() Best, Gian |
Hi Guys,
one more question here... Can i use the speed signal from the gearbox instead of the speedometer unit? If yes, can someone tell me where i can find the speed signal on the gearbox on my 2.4 and which cable color i have to use? thx gian |
