Home > Maintenance & Modifications > Need help with cruise control wiring – 2.4l
Donleguano
Switzerland 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
Hi Guys,
i just received the cruise control for my Defender 2.4l.
Im a bit confused by the wiring diagram, i hope you can help me out here.
Attached you find some pictures.
the upper connector shows a yellow cable which has to go on a red cable, but which red cable?
And where does the red cable go then?
The lower connector shows a blue cable which has to go on the red cable witch has a fuse.
Can you help me out here?
Thx!
Gian
Post #907960 15th Jun 2021 5:13pm
Bluest
What brand is the cruise control? I have a Mobile Centre one which is a rebranded LiteOn Unit. If yours is the same I could scan my wiring instructions for you in case that helps. 2007 110 TDCi Station Wagon XS
Post #907963 15th Jun 2021 5:32pm
Donleguano
Thx, but its not the same i think.
Its one from Britpart, manufacturer is from Denmark.
The Name of the Cruise Control is: E-Cruise Control. Several other shops sell this, also Nakatanenga from Germany...
Thx for the Help!
Post #907965 15th Jun 2021 5:36pm
Donleguano
Hi Guys,
now everything is clear – thx anyway for the help!
Have an other question. Has anyone crimped the cables instead of soldering?
thx
Post #907984 15th Jun 2021 6:29pm
Bluest
I almost always crimp rather than solder. 2007 110 TDCi Station Wagon XS
Post #907988 15th Jun 2021 6:47pm
PCM
See below for step by step images, It's a 2-3 hour job.
https://www.autoexpress.co.uk/land-rover/1...u-defender
Post #907992 15th Jun 2021 6:50pm
Donleguano wrote:
... Has anyone crimped the cables instead of soldering?
thx
There are several fairly compelling engineering reasons why crimping is more satisfactory and more durable than soldering.
Post #907993 15th Jun 2021 6:53pm
Donleguano
Thx guys for your help Bow down
I will crimp for sure then. Im not very talented in soldering Rolling Eyes
And thx for the step by step guide!
This helps a lot… the only thing there which does not show is the yellow/blue cable for the 2.4
But bith go into the red with fuse Thumbs Up
Best,
Gian
Post #908027 15th Jun 2021 9:09pm
Donleguano
Hi Guys,
one more question here...
Can i use the speed signal from the gearbox instead of the speedometer unit?
If yes, can someone tell me where i can find the speed signal on the gearbox on my 2.4 and which cable color i have to use?
thx
gian
Post #908275 17th Jun 2021 9:18am
