Home > Td5 > Parasitic load/quiescent load on a TD5 2001 90 |
MC84 Member Since: 23 May 2016 Location: Near Bristol Posts: 341 |
Hi, can anyone give me an idea of what the current draw from my battery should be when everything is off? I don't have an alarm or any fancy add on's. I have looked on the forum and I see 25ma is a figure I should be aiming for. Just wondered if anyone can confirm please?
Thanks in advance. Mike Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
8th Jun 2021 6:38pm |
Well Mike, now you mention it I do have a tracker. I'll unhook it and see what I get then. Thanks for the memory jogger!
Still be interested in the "normal" current draw though. Mike Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
8th Jun 2021 7:12pm |
8th Jun 2021 7:26pm |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 904 |
Good luck, unfortunately I am unable to give you that
Hope you get it resolved either way Mike |
9th Jun 2021 5:27pm |
Mike
9th Jun 2021 5:37pm |
T140 Member Since: 15 Mar 2016 Location: Ayrshire Posts: 163 |
I had a parasitic load on my 90, it was water ingress in an interior light. nobody is perfect but being Scottish is a start
10th Jun 2021 12:07pm |
I've taken another look at the "issue". It appears that the Truck is indeed drawing around 25ma when idle. Acceptable in my book. Now the things I have added made for the total of around 135ma.
Truck 25ma Flashing LED on the dash 20ma (need to rethink this one) Tracker, now unused 25ma Deployable step 65ma!! (Need to look at that ASAP. Easy fix so will be onto that in a few days.) Mike Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
10th Jun 2021 12:21pm |
