Home > Td5 > Parasitic load/quiescent load on a TD5 2001 90
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
Hi, can anyone give me an idea of what the current draw from my battery should be when everything is off? I don't have an alarm or any fancy add on's. I have looked on the forum and I see 25ma is a figure I should be aiming for. Just wondered if anyone can confirm please?
Thanks in advance. Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #906934 8th Jun 2021 6:38pm
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
Are you sure? My first Defender had constant drain and it turned out to be an old mid 90s tracker unit hidden, and the battery backup on it had long since expired, an auto electrician traced it in the end, worth mentioning just in case.
Mike
Post #906937 8th Jun 2021 6:45pm
MC84
Well Mike, now you mention it I do have a tracker. I'll unhook it and see what I get then. Thanks for the memory jogger!
Still be interested in the "normal" current draw though. Mike
Ford 100e 1959
Post #906941 8th Jun 2021 7:12pm
MC84
Ford 100e 1959
Post #906942 8th Jun 2021 7:26pm
Mike c
Good luck, unfortunately I am unable to give you that
Hope you get it resolved either way
Mike
Post #907068 9th Jun 2021 5:27pm
MC84
Thumbs Up Mike
Ford 100e 1959
Post #907071 9th Jun 2021 5:37pm
T140
Scotland 2007 Defender 90 Td5 HT Zambezi Silver
I had a parasitic load on my 90, it was water ingress in an interior light. nobody is perfect but being Scottish is a start
Post #907202 10th Jun 2021 12:07pm
MC84
I've taken another look at the "issue". It appears that the Truck is indeed drawing around 25ma when idle. Acceptable in my book. Now the things I have added made for the total of around 135ma.
Truck 25ma
Flashing LED on the dash 20ma (need to rethink this one)
Tracker, now unused 25ma
Deployable step 65ma!! (Need to look at that ASAP. Easy fix so will be onto that in a few days.) Mike
Ford 100e 1959
Post #907207 10th Jun 2021 12:21pm
