Home > Maintenance & Modifications > Puma 4 point SD internal cage- how to fit rear window trim
big110
 2014 Defender 110 Puma 2.2 SW Keswick Green
I’ve got my safety devices 4 point bolt in cage installed. The instructions call to trim more cut the interior panel slightly so that you can fit the rear window trim back on. Has anyone done this?
Post #906607 6th Jun 2021 4:19am
donmacn
I have a Puma cage - but in a Tdi era vehicle.
As far as I can remember I didn't have to cut the trim, but I can check and take any specific pictures you might like?
Edit - on reflection I'm not really sure my cage is the same thing. Mine is an internal cage, which bolts through the 2nd row floor, just by the seatbelt mounts, and onto the rear wing internal bracing.
But I don't think you'd get the trim back on once you've fitted it. I left my trim in place, and then fitted the cage.
So - sorry - not sure I've been much help. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #906632 6th Jun 2021 10:47am
