![]() | Home > Maintenance & Modifications > Puma 4 point SD internal cage- how to fit rear window trim |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1910 ![]() ![]() |
I have a Puma cage - but in a Tdi era vehicle.
As far as I can remember I didn't have to cut the trim, but I can check and take any specific pictures you might like? Edit - on reflection I'm not really sure my cage is the same thing. Mine is an internal cage, which bolts through the 2nd row floor, just by the seatbelt mounts, and onto the rear wing internal bracing. But I don't think you'd get the trim back on once you've fitted it. I left my trim in place, and then fitted the cage. So - sorry - not sure I've been much help. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
