![]() | Home > Maintenance & Modifications > Puma: sticky 2nd gear |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2684 ![]() ![]() ![]() |
Hi gents,
Recently I've started noticing that the 2nd gear in my Puma is very sticky, only really happens in the morning. But now it's getting so bad that when I tried to go out this morning (at around 10 am), I almost had to park the car down the street as I couldn't get into 2nd. The mech says a few Puma owners have also reported the same. They reckon putting 500-750ml of ATF in the gearbox solves this - what do you guys reckon? Thanks -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Now on 85,000 km --
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 688 ![]() ![]() |
Not a synchro then... Well shouldn't be. It's too young.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3640 ![]() ![]() ![]() |
Could be one of the detents?
ATF fluid was spec’d for the lt77. Not very good for lubrication, but apparently helps shifting. MT82 is very different, and I would be hesitant to add ATF. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Thanks.
Mech reckons we do a complete fluid change with something full synth, like Motul or Redline. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781 ![]() ![]() ![]() |
Needs to be GL4 spec. Rgds. Chris |
Griff90bowler Member Since: 24 Feb 2021 Location: Cowbridge Posts: 140 ![]() ![]() |
I put Fuchs TITAN SINTOPOID LS SAE 75W-90 in all the drive train on mine
I'm going with Redline MTL MTL® 75W80 GL-4 Gear Oil: http://chemsailoils.co.za/product/mtl-75w80-gl-4-gear-oil/
Not cheap, but will see what it does and report back. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Ok, Redline's been in for about a week now.
Gearshifts are definitely smoother, but there's still a bit of 'sticky' in that 2nd gear - whether it's 1st to 2nd or 2nd to 3rd/vice versa. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
