Home > Maintenance & Modifications > Puma: sticky 2nd gear
Naks
Hi gents,
Recently I've started noticing that the 2nd gear in my Puma is very sticky, only really happens in the morning.
But now it's getting so bad that when I tried to go out this morning (at around 10 am), I almost had to park the car down the street as I couldn't get into 2nd.
The mech says a few Puma owners have also reported the same.
They reckon putting 500-750ml of ATF in the gearbox solves this - what do you guys reckon?
Thanks --
Post #906316 3rd Jun 2021 1:41pm
Matt110
How many miles has it done? If the 2nd gear synchro is worn and it needs replacing, you may well get a few more thousand miles out of the box by reducing the viscosity of the oil, but at the cost of the whole of the rest of the box.
Post #906319 3rd Jun 2021 2:13pm
Naks
Now on 85,000 km --
Post #906321 3rd Jun 2021 2:53pm
Matt110
Not a synchro then... Well shouldn't be. It's too young.
Post #906322 3rd Jun 2021 2:59pm
Dinnu
Could be one of the detents?
ATF fluid was spec’d for the lt77. Not very good for lubrication, but apparently helps shifting.
MT82 is very different, and I would be hesitant to add ATF. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #906334 3rd Jun 2021 4:28pm
Naks
Thanks.
Mech reckons we do a complete fluid change with something full synth, like Motul or Redline. --
Post #906335 3rd Jun 2021 4:30pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Needs to be GL4 spec. Rgds.
Chris
Post #906353 3rd Jun 2021 7:02pm
Griff90bowler
Wales
I put Fuchs TITAN SINTOPOID LS SAE 75W-90 in all the drive train on mine
Post #906396 3rd Jun 2021 10:37pm
Naks
I'm going with Redline MTL MTL® 75W80 GL-4 Gear Oil: http://chemsailoils.co.za/product/mtl-75w80-gl-4-gear-oil/
Not cheap, but will see what it does and report back. --
Post #906889 8th Jun 2021 8:08am
Naks
Ok, Redline's been in for about a week now.
Gearshifts are definitely smoother, but there's still a bit of 'sticky' in that 2nd gear - whether it's 1st to 2nd or 2nd to 3rd/vice versa. --
Post #909748 28th Jun 2021 10:00am
