Home > Technical > Axle differences 95 D90 and 09 110??
nikojo
Are there any differences between the axles in a 1995 D90 and a 2009 110 Puma???
Specifically can I swap the ARB lockers and their axles out of the D90 and bolt them up into the Puma???
Front and Rear??
Post #85327 20th Aug 2011 4:53am
Front: should be the same
Rear: not too sure, think the puma 110 (RD128?) is different to the earlier 90 (RD56) type.
Post #85384 20th Aug 2011 6:15pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
The front should be ok but the rear in the puma is different.
Post #85387 20th Aug 2011 6:24pm
nikojo
Thanks guys.
So I CAN switch BOTH the halfshafts AND the CV's AND the ARB locker from the D90 to the Puma.
But for the rear I have to get them specifically for the Puma.
Yes?
How about the front driveshaft/propshaft??? Will the D90 bolt up in the 110??
Post #85425 21st Aug 2011 3:43am
1995 sounds like it's a 300Tdi?? in which case, the front shaft won't fit the puma... too long (only by about an inch or so)
Td5/puma front props are the same length though.
If yours is a special prop (double CV/wide angle etc) you could get oit shortened.... or if you're handy with a welder and grinder, shorten it yourself, es no difficile.
Post #85431 21st Aug 2011 7:35am
