![]() | Home > Technical > Axle differences 95 D90 and 09 110?? |
nikojo Member Since: 06 Aug 2011 Location: Madrid Posts: 75 ![]() |
Are there any differences between the axles in a 1995 D90 and a 2009 110 Puma???
Specifically can I swap the ARB lockers and their axles out of the D90 and bolt them up into the Puma??? Front and Rear?? |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
The front should be ok but the rear in the puma is different.
Thanks guys.
So I CAN switch BOTH the halfshafts AND the CV's AND the ARB locker from the D90 to the Puma. But for the rear I have to get them specifically for the Puma. Yes? How about the front driveshaft/propshaft??? Will the D90 bolt up in the 110?? |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6198 ![]() ![]() ![]() |
1995 sounds like it's a 300Tdi?? in which case, the front shaft won't fit the puma... too long (only by about an inch or so)
Td5/puma front props are the same length though. If yours is a special prop (double CV/wide angle etc) you could get oit shortened.... or if you're handy with a welder and grinder, shorten it yourself, es no difficile. |
