![]() | Home > Technical > Help request |
slon4eto Member Since: 30 Aug 2020 Location: Moscow Posts: 7 ![]() ![]() |
Hello, I want to change my clutch kit.
My truck is a Land Rover Defender 110 HARD TOP 300TDI. It was produced on 1997. The engine is 300tdi. The gearbox is R 380 . Please answer the following questions: A) Which clutch is preferable / you would use /, for what reasons : 1) Land Rover Performance Clutch Kit - OE STC8358 manufactured by the company SACHS : https://www.sachsperformance.com/en/clutch...00950701-s OR 2)POWERspec TDI 200/300tdi manufactured by the company LOF clutches : https://lofclutches.com/shop/clutches/clut...ty-clutch/ B) For LOF clutches: 1) What is the % higher transmitted torque of the POWERspec TDI 200/300 tdi kit compared to OEM? https://lofclutches.com/shop/clutches/clut...ty-clutch/ 2) What is the torque capacity of the POWERspec TDI 200/300 tdi kit in Nm ? https://lofclutches.com/shop/clutches/clut...ty-clutch/ 3) What is the clamping force /eject fors/ of the POWERspec TDI 200/300 tdi kit in N or kg ? https://lofclutches.com/shop/clutches/clut...ty-clutch/ 4) What will be the weight of the pedal if I install /put/ a 2.8 TGV HS International POWERspec kit - (Also fits TDI) and a DEFENDER POWER MASTER BUNDLE Spring and Master Cylinder on my truck? https://lofclutches.com/shop/clutches/clut...rspec-kit/ https://lofclutches.com/shop/clutches/peda...-cylinder/ 5) The weight of the pedal from point 4) is equal to or less or greater than if I mount /put/ on my truck POWERspec TDI 200/300 tdi kit and Defender POWER MASTER BUNDLE Spring and Master Cylinder? https://lofclutches.com/shop/clutches/clut...ty-clutch/ https://lofclutches.com/shop/clutches/peda...-cylinder/ Thank you in advance. I do not speak English! I use google translator. |
I close the failed discussion.
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3771 ![]() ![]() ![]() |
If you don’t yet have the answer I would suggest you contact Luke at LOF directly.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3615 ![]() ![]() ![]() |
Was answered in another thread. https://www.defender2.net/forum/topic78705.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Thank you
