![]() | Home > Technical > TD5 Starting Issues |
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 ![]() ![]() ![]() |
Hi,
Td5 has gone from starting on the button to struggling a bit - takes longer sometimes, needing a couple of goes? Before I go fumbling under the bonnet, any thoughts. Steve ![]() Discovery 3 HSE BMW 330i Coupe |
fue pressure, either the pump, the filter or the pressure reg.
put the ignition on and listen by the front wheel for the sounds of rushing diesel, mine did that and it was the pressure reg |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 339 ![]() ![]() ![]() |
If it only does this from cold it could also be one or more of the glow plugs.
Landyash Member Since: 06 Feb 2011 Location: Nottinghamshire Posts: 287 ![]() ![]() ![]() |
Could also be the injector seals,have they been changed?
It happened to my old TD5 Good look ![]() |
Landy nut Member Since: 22 Dec 2007 Location: In hiding Posts: 154 ![]() ![]() ![]() |
Bet you its the fuel pressure regulator or starter motor contacts. If its the FPR, take off the black plastic cover from the engine and look for a leak somewhere near the back of the block on the drivers side. If not, it could still well be it. Get it changed. Bit of a crap job to do, but will make all the difference. If its the starter motor contacts, you can get a kit for less than £10 to do it.
