Home > Technical > TD5 Starting Issues
stevie d
United Kingdom 2003 Defender 90 Td5 SW Alpine White
TD5 Starting Issues
Hi,
Td5 has gone from starting on the button to struggling a bit - takes longer sometimes, needing a couple of goes?
Before I go fumbling under the bonnet, any thoughts.
Steve Thumbs Up Defender 90 TD5 Station Wagon
Discovery 3 HSE
BMW 330i Coupe
Post #85290 19th Aug 2011 9:04pm
T1G UP
fue pressure, either the pump, the filter or the pressure reg.
put the ignition on and listen by the front wheel for the sounds of rushing diesel, mine did that and it was the pressure reg
Post #85299 19th Aug 2011 9:56pm
Laurie
Had the same problem a year ago.
Appeared to be the yellow fuel pump relay under the driver's seat. Changing it cured the problem for a while. Put your finger on it while cranking to see if it vibrates. I think it's the second from the rear.
Ultimately turned out to be reduced battery voltage while crankng, causing the relay to 'stutter'.
You may need a new battery. (Mine was six years old.) See if it cures with a second (additional) battery on jump leads.
Post #85323 20th Aug 2011 12:58am
Fifth Horseman
If it only does this from cold it could also be one or more of the glow plugs.
Post #85342 20th Aug 2011 8:40am
Landyash
England 2007 Defender 110 Puma 2.4 DCPU Stornoway Grey
Could also be the injector seals,have they been changed?
It happened to my old TD5
Good look Thumbs Up
Post #87273 2nd Sep 2011 8:12pm
Landy nut
United Kingdom 2006 Defender 90 Td5 PU Epsom Green
Bet you its the fuel pressure regulator or starter motor contacts. If its the FPR, take off the black plastic cover from the engine and look for a leak somewhere near the back of the block on the drivers side. If not, it could still well be it. Get it changed. Bit of a crap job to do, but will make all the difference. If its the starter motor contacts, you can get a kit for less than £10 to do it.
Post #87292 2nd Sep 2011 9:08pm
