Home > Puma (Tdci) > DPF issues |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7866 |
The Puma has been sat up for a few weeks, flat battery, jump started fine. Then sat again for 2 weeks, this time left on trickle charge, battery dead, jump started. Running in limp mode with dfp light on.
Battery was dead so new battery, tried reset faults but persists. Visit to local LR Specialist, to investigate limp mode, caused by DFP forcing limp mode. Can't force a regen, saying low volts but battery tested fine. Left it with them for further playing but looking like DPF might be f#@!* Anything else worth trying/looking at? Thanks James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
21st May 2021 3:34pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1695 |
Is there any reason why the dpf may be blocked, ie lots of short journeys, or just starting engine and leaving running on your drive to charge battery lots of times ?
If not I’m wondering what’s triggered this because as long as you usually do regular runs at 60 plus mph on 30 mins journeys it should not be a Full dpf issue . Perhaps it’s a sensor relating to the DPF or electrical connection between sensor and ECU ? May even be the ECU as sometimes they can be effected by draining batteries or jump starting. Hopefully your indi can diagnose and rectify if it’s one of these issues. Have a look at this diagram for all the sensors https://www.lrworkshop.com/diagrams/land-r...10_2.2tdci If it is a full DPF all may not be lost as there are specialist companies that can clean them out. |
21st May 2021 4:34pm |
Thanks Ian. I've no reason to think the dpf is full, the light has only just come on once before and a good run cleared it ok and same use now.
My first thought is the jump start has damaged something electrical, but can't see why/how it can damage the physical dpf, so definitely worth looking at the electric elements. Thanks. James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
21st May 2021 6:57pm |
Farmerben Member Since: 16 Jan 2017 Location: Herefordshire Posts: 604 |
https://www.defender2.net/forum/topic68005.html
Have you seen this thread? https://instagram.com/bentheoandrews |
21st May 2021 8:24pm |
Thanks Ben! Sounds exactly the same issue, doesn't sound as serious as I'm thinking. James
21st May 2021 9:37pm |
To update and close this thread... all fixed!!
It was worked on over the weekend by the excellent Cult 4x4 . It was reading limp mode forced by blocked dpf filter. Tried forced regen but wouldn't due to low voltage. Test drives, battery boasts, disconnect all auxiliaries, still no joy. Thanks to Scott and Ben highlighting above thread which described exactly same symptons. John at Cult 4x4 spoke with Chris at CSK bounced ideas about and eventually via the Hawkeye alone it was all resolved. All it needed was a "Parameters" reset! Not entirely sure what this is or does but it's done the job. Out of limp mode, no regen required, running 100% again. Huge relief after think I was in for a huge bill for a new DPF. Thanks to all the advice from Def2, Angry Pumas, CSK and especially Cult 4x4!!! Click image to enlarge James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
26th May 2021 9:27pm |
That’s good to here, I’m assuming the battery problem must have caused the Engine ECU to get mixed up.
I’m wondering if a “parameters” reset or equivalent is available via a Nanocom. The Nanocom has DPF reset and DPF pressure sensor reset as options. Any one know for sure ? |
26th May 2021 9:50pm |
I can only assume the jump start caused a spike to cause the problem somewhere, ECU I guess.
All I know is it was all done via a Hawkeye and a bit of trial and error. They had tried a DPF reset but it wouldn't due to low voltage. But somewhere deep in the menu they found a parameter reset. They thought the parameters were possibly related to the ECU 'learning' your driving style? Just pleased it was all sorted without a big bill!! James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
27th May 2021 7:19am |
Great news! https://instagram.com/bentheoandrews
27th May 2021 7:23am |
