Home > Puma (Tdci) > DPF issues
JOW240725
DPF issues
The Puma has been sat up for a few weeks, flat battery, jump started fine. Then sat again for 2 weeks, this time left on trickle charge, battery dead, jump started. Running in limp mode with dfp light on.
Battery was dead so new battery, tried reset faults but persists. Visit to local LR Specialist, to investigate limp mode, caused by DFP forcing limp mode. Can't force a regen, saying low volts but battery tested fine.
Left it with them for further playing but looking like DPF might be f#@!*
Anything else worth trying/looking at? Big Cry
Thanks James
Instagram @suffolk_rovers
Post #904311 21st May 2021 4:34pm
Ianh
Is there any reason why the dpf may be blocked, ie lots of short journeys, or just starting engine and leaving running on your drive to charge battery lots of times ?
If not I’m wondering what’s triggered this because as long as you usually do regular runs at 60 plus mph on 30 mins journeys it should not be a Full dpf issue .
Perhaps it’s a sensor relating to the DPF or electrical connection between sensor and ECU ? May even be the ECU as sometimes they can be effected by draining batteries or jump starting. Hopefully your indi can diagnose and rectify if it’s one of these issues.
Have a look at this diagram for all the sensors
https://www.lrworkshop.com/diagrams/land-r...10_2.2tdci
If it is a full DPF all may not be lost as there are specialist companies that can clean them out.
Post #904320 21st May 2021 5:34pm
JOW240725
Thanks Ian. I've no reason to think the dpf is full, the light has only just come on once before and a good run cleared it ok and same use now.
My first thought is the jump start has damaged something electrical, but can't see why/how it can damage the physical dpf, so definitely worth looking at the electric elements. Thanks. James
Post #904349 21st May 2021 7:57pm
Ianh
This leaves Three options
1. it’s an ECU problem due to an electrical spike associated with battery failure, jump starting and battery replacement.
2. Sensor failure or sensor electrical connection. It could be that sensor failure or electrical connection failure from the sensor has been getting worse over time, prohibiting a DPF regen happening and the latest restart involving battery change has tipped it over the edge.
3. DPF is full.
in order get them to check 2. Then 1, if not it only leaves 3.
Others will Know better, perhaps Martin. But can you reset the engine ECU to the factory default for your vehicle, as after checking option 2 that would be my next thing to try..
Post #904358 21st May 2021 9:04pm
Farmerben
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
Post #904360 21st May 2021 9:24pm
JOW240725
Thanks Ben! Sounds exactly the same issue, doesn't sound as serious as I'm thinking. James
Post #904368 21st May 2021 10:37pm
JOW240725
To update and close this thread... all fixed!!
It was worked on over the weekend by the excellent Cult 4x4 . It was reading limp mode forced by blocked dpf filter. Tried forced regen but wouldn't due to low voltage. Test drives, battery boasts, disconnect all auxiliaries, still no joy.
Thanks to Scott and Ben highlighting above thread which described exactly same symptons. John at Cult 4x4 spoke with Chris at CSK bounced ideas about and eventually via the Hawkeye alone it was all resolved.
All it needed was a "Parameters" reset! Not entirely sure what this is or does but it's done the job. Out of limp mode, no regen required, running 100% again.
Huge relief after think I was in for a huge bill for a new DPF. Thanks to all the advice from Def2, Angry Pumas, CSK and especially Cult 4x4!!! Thumbs Up
 James
Post #905219 26th May 2021 10:27pm
Ianh
That’s good to here, I’m assuming the battery problem must have caused the Engine ECU to get mixed up.
I’m wondering if a “parameters” reset or equivalent is available via a Nanocom. The Nanocom has DPF reset and DPF pressure sensor reset as options.
Any one know for sure ?
Post #905223 26th May 2021 10:50pm
JOW240725
I can only assume the jump start caused a spike to cause the problem somewhere, ECU I guess.
All I know is it was all done via a Hawkeye and a bit of trial and error. They had tried a DPF reset but it wouldn't due to low voltage. But somewhere deep in the menu they found a parameter reset. They thought the parameters were possibly related to the ECU 'learning' your driving style?
Just pleased it was all sorted without a big bill!! Thumbs Up Bow down James
Post #905249 27th May 2021 8:19am
Farmerben
Post #905250 27th May 2021 8:23am
