![]() | Home > Puma (Tdci) > Puma piston cooling jets and fuel pump torque values please. |
Gloucesternige Member Since: 17 Jan 2020 Location: In the garage Posts: 114 ![]() ![]() ![]() |
Can someone please help.. I am rebuilding my Puma 2.4 and the useless manual doesnt even mention removal of or fitting the PCJ's and hence has no torque value for them. Can anyone please advise?
There is also no mention of the large nut holding the hub onto the fuel pump, so no torque there either. I realise the manual is freely available online, but it is pretty useless. no bearing clearance specs, bits completely missing and all over the place in running order. Grrr Nige Check out my You Tube channel https://www.youtube.com/c/Defender90KeswickNigelsLandRoverchannel |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3784 ![]() ![]() ![]() |
By the way, been watching the YouTube channel for a few months now. Great stuff, keep it coming.
Yeah, it's shown there but no mention of them in the build sequence?? Nige Check out my You Tube channel https://www.youtube.com/c/Defender90KeswickNigelsLandRoverchannel |
Thank you very much. Nige Check out my You Tube channel https://www.youtube.com/c/Defender90KeswickNigelsLandRoverchannel |
The other way to look at it would be what size are the bolts and what grade are they. You could then use a standard torque value for those bolts. Like this: https://www.fastenermart.com/files/metric_tighten_torques.pdf
I have actually just finished making a video and said exactly that @Co1. Torque is just under 12Nm as the bolts are 8.8. Nige
I’ll expect a special mention in the credits!!
Sorry, I filmed it before your comment, otherwise I would give you a shout out!! 😂😂 Nige
No worries, there’s always the next episode!!
