Home > Puma (Tdci) > Puma piston cooling jets and fuel pump torque values please.
Gloucesternige
United Kingdom 2011 Defender 90 Puma 2.4 HT Keswick Green
Can someone please help.. I am rebuilding my Puma 2.4 and the useless manual doesnt even mention removal of or fitting the PCJ's and hence has no torque value for them. Can anyone please advise?
There is also no mention of the large nut holding the hub onto the fuel pump, so no torque there either.
I realise the manual is freely available online, but it is pretty useless. no bearing clearance specs, bits completely missing and all over the place in running order.
Grrr Nige
Check out my You Tube channel
https://www.youtube.com/c/Defender90KeswickNigelsLandRoverchannel
Post #903049 14th May 2021 6:11pm
Co1
I can’t help off the top of my head. But I have the 2012 onwards manual and that does show the piston cooling jet assembly. Can’t see it being any different so would probably be worth downloading that to fill in any gaps.
Post #903055 14th May 2021 6:30pm
Co1
By the way, been watching the YouTube channel for a few months now. Great stuff, keep it coming.
Post #903056 14th May 2021 6:30pm
Gloucesternige
Yeah, it's shown there but no mention of them in the build sequence?? Nige
Post #903059 14th May 2021 6:33pm
Gloucesternige
Thank you very much. Nige
Post #903060 14th May 2021 6:34pm
Co1
The other way to look at it would be what size are the bolts and what grade are they. You could then use a standard torque value for those bolts. Like this: https://www.fastenermart.com/files/metric_tighten_torques.pdf
Post #903086 14th May 2021 7:44pm
Gloucesternige
I have actually just finished making a video and said exactly that @Co1. Torque is just under 12Nm as the bolts are 8.8. Nige
Post #903088 14th May 2021 7:55pm
Co1
I’ll expect a special mention in the credits!!
Post #903090 14th May 2021 8:08pm
Gloucesternige
Sorry, I filmed it before your comment, otherwise I would give you a shout out!! 😂😂 Nige
Post #903099 14th May 2021 8:47pm
Co1
No worries, there’s always the next episode!!
Post #903114 14th May 2021 10:05pm
