![]() | Home > Puma (Tdci) > Non-A/C Climate Control |
Smyles_ Member Since: 26 Aug 2018 Location: Copenhagen Posts: 520 ![]() ![]() |
Hi guys,
So I've moved from a TD5 to a Non-A/C 2.4 Tdci and I was messing about with the climate controls yesterday right before I drove back into the workshop. To my surprise the lower slider (highlighted) wouldn't budge from what I remember was the far right position. ![]() Click image to enlarge My question is, is it broken? I'm gonna hazard a guess and say yes, although I never had a chance to ask the mechanics. Also, what differences is there between the A/C and non-A/C spec'd pumas? As far as I'm aware there's no difference with the number of vents? Cheers ![]() ![]() Cummins 130 Build Thread 58 130 Double Cab HCPU - Cairns Blue 04 110 Double Cab - Black (gone) 07 Audi RS4 Avant - Silver |
Yes, it's broken, unfortunately. All that lever does is change from incoming fresh air to recirculating and isn't related to the A/C operation.
There are no physical differences in the cab between A/C and non-A/C models except for the button to turn A/C on. Externally, you'll have the flat fronted radiator grill instead of the protruding A/C one. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Thank you both for answering that and the questions that I was going to follow up with.
![]() Will be upgrading it down the line with A/C so good to know, cheers! ![]() ![]() Cummins 130 Build Thread 58 130 Double Cab HCPU - Cairns Blue 04 110 Double Cab - Black (gone) 07 Audi RS4 Avant - Silver |
At £160 I'm certain I will be able to fix it! Stuart
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17936 ![]() ![]() ![]() |
Yes, it is an absurd price for a rather crappy plastic jobbie!
Just remember that with a/c you have yet more things to go wrong. |
CharlieDonuts Member Since: 16 Jun 2019 Location: Illiers Combray Posts: 133 ![]() ![]() ![]() |
Mine was stuck for a long time but I kept fiddling with it and finally it came loose. I never really understood why you would want recycled air over fresh air ? Is it something to do with manure ?
I use it as a means to close off the intake, which otherwise seems to let a constant low level draft through. Can also help with warming up on a cold morning but not for too long as moisture tends to build up too. Darren
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2677 ![]() ![]() |
Had something similar with mine,
luckily it had just got jammed? there's a cable like what I would describe a Mtb shift cable that comes out passenger side bulkhead under the bonnet, it looked like it'd been over rotated I manually pushed it back and it's worked ever since (2 years +) |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1125 ![]() ![]() ![]() |
https://en.wikipedia.org/wiki/Bowden_cable ![]() |
JR Member Since: 07 Dec 2012 Location: Auchtermuchty Posts: 532 ![]() ![]() ![]() |
We had that problem on our 2010 Tdci, luckily JLR's warranty fitted a new heater unit! This was back in 2013, though!
