Home > Puma (Tdci) > Non-A/C Climate Control
Smyles_
Denmark 2008 Defender 130 Puma 2.4 HCPU Cairns Blue
Hi guys,
So I've moved from a TD5 to a Non-A/C 2.4 Tdci and I was messing about with the climate controls yesterday right before I drove back into the workshop. To my surprise the lower slider (highlighted) wouldn't budge from what I remember was the far right position.
My question is, is it broken? I'm gonna hazard a guess and say yes, although I never had a chance to ask the mechanics.
Also, what differences is there between the A/C and non-A/C spec'd pumas? As far as I'm aware there's no difference with the number of vents?
Cheers Thumbs Up Stuart
Cummins 130 Build Thread
Instagram
04 110 Double Cab - Black (gone)
58 130 Double Cab HCPU - Cairns Blue
Post #897549 11th Apr 2021 9:01pm
Yes, it's broken, unfortunately. All that lever does is change from incoming fresh air to recirculating and isn't related to the A/C operation.
There are no physical differences in the cab between A/C and non-A/C models except for the button to turn A/C on. Externally, you'll have the flat fronted radiator grill instead of the protruding A/C one. Darren
Post #897569 11th Apr 2021 9:40pm
The only difference between a/c and non-a/c is that there is an additional heat exchanger built into the heater box in the dash on the a/c models, together with the refrigerant system etc needed to support it. The air passages and control flaps are exactly the same.
As noted above, if the slider is stuck it is probably an indication that the slider control unit has broken, which is a shame as it is absurdly expensive. The flap that it operates is above the passengers feet, so it might be worth checking that there isn't something physically stuck ion the mechanism before starting the dismantling process.
The heater controls on the Puma sadly do not exude quality and are rather prone to breakage.
Post #897592 11th Apr 2021 10:47pm
Smyles_
Thank you both for answering that and the questions that I was going to follow up with. Laughing
Will be upgrading it down the line with A/C so good to know, cheers! Thumbs Up Stuart
Instagram
Post #897596 11th Apr 2021 11:16pm
Smyles_
At £160 I'm certain I will be able to fix it! Stuart
Instagram
Post #897599 11th Apr 2021 11:46pm
Yes, it is an absurd price for a rather crappy plastic jobbie!
Just remember that with a/c you have yet more things to go wrong.
Post #897601 11th Apr 2021 11:54pm
CharlieDonuts
France 2008 Defender 90 Puma 2.4 SW Galway Green
Mine was stuck for a long time but I kept fiddling with it and finally it came loose. I never really understood why you would want recycled air over fresh air ? Is it something to do with manure ?
Post #897646 12th Apr 2021 9:00am
I use it as a means to close off the intake, which otherwise seems to let a constant low level draft through. Can also help with warming up on a cold morning but not for too long as moisture tends to build up too. Darren
Post #897648 12th Apr 2021 9:16am
Likeomg
Had something similar with mine,
luckily it had just got jammed? there's a cable like what I would describe a Mtb shift cable that comes out passenger side bulkhead under the bonnet, it looked like it'd been over rotated I manually pushed it back and it's worked ever since (2 years +)
Post #897651 12th Apr 2021 9:23am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
https://en.wikipedia.org/wiki/Bowden_cable
Smile
Post #898041 13th Apr 2021 6:26pm
JR
Scotland 1984 Defender 90 200 Tdi SW Coniston Green
We had that problem on our 2010 Tdci, luckily JLR's warranty fitted a new heater unit! This was back in 2013, though!
Post #899413 21st Apr 2021 9:53pm
