![]() | Home > Maintenance & Modifications > Uproar 4x4 Stealth Rock Sliders. |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 751 ![]() ![]() ![]() |
All the Uproar stuff I've had has been excellent.
Another yes vote for uproar 4x4's gear. Excellent quality.
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4317 ![]() ![]() ![]() |
So the paint/powder coat seems to stay attached to the stainless? Stainless is normally is normally a nightmare for coatings 2007 110 TDCi Station Wagon XS
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2541 ![]() ![]() ![]() |
How stainless steel is powder coated.
https://www.fsinox.com/stainless-steel-is-powder-coated/ Defender 90XS SW Mini Countryman Cooper S Morgan Plus 8 |
chrisc2306 Member Since: 02 Jan 2020 Location: Glasgow Posts: 60 ![]() ![]() ![]() |
I’ll give another +1 for uproar stuff, got quite a bit of it on my defender and it is holding up really well
MichaelE Member Since: 18 Jan 2020 Location: Crawley West Sussex Posts: 155 ![]() ![]() |
Be aware of one potential fitting problem. Most of these rock sliders have a tube at the rear which slides in to the rear outrigger tube. I have Uproar Hurricanes and I had a mother of a job getting this tube to slide in to my outriggers. I had conversation with Uproar over the close tolerance and no allowance for older outriggers that aren't as new. They said all their rock sliders fit this way.
I was fortunate in having a milling cutter just the right size to stick on a drill and wack it up and down both outrigger tubes to clear out the wax protection and heavy underlying rust. It took some effort, and I still had to cut a couple of inches off the tube to allow it to go in far enough [Uproar's suggestion] assisted by grease and a hammer. Otherwise my only option would have been to cut off the outriggers and weld on new ones. |
True Defender owner logic, bodge new shiny parts into a rusty crusty chassis...
Is that the same for a 110? Not familiar with the outrigger tube. 2007 110 TDCi Station Wagon XS |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915 ![]() ![]() ![]() |
No, that is a problem unique to the 90; 110 and 130 vehicles do not have the tubular outrigger.
Oy! My tubes aren't crusty. It's internal patina. |
Ghound Member Since: 03 Jul 2018 Location: northern ireland Posts: 45 ![]() ![]() ![]() |
I make galvanised one's for 110's, but trying to get a courier to take them to the Mainland is impossible, so i just do them for local customers.
![]() Click image to enlarge ![]() Click image to enlarge |
SJM2018 Member Since: 06 Jul 2018 Location: Bristol Posts: 296 ![]() ![]() ![]() |
That front bumper is a bit of a beast
It's coming off in a few weeks as I'm knocking up a double tubular type with winch mount
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3499 ![]() ![]() ![]() |
Look great. Can you jack off them? 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
