Home > Puma (Tdci) > MOT & Exhaust condition query
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
My 110 is due an MOT shortly and on checking over its got a small leak (looks like its splitting on the side seam) from the centre box on the exhaust. I've had a stainless replacement recommended but its unlikely to get hear in time for me to fit before the MOT.
Any experience or links to good information sources on how bad the leak needs to be before it becomes a fail rather than an advisory on the MOT?
Thanks Keith
Post #893531 23rd Mar 2021 8:44pm
markb110
Can you go old school and buy an exhaust repair thingy from Halfords along with a tin of Dum Dum.
When i was started driving we would use an old Coke tin, exhaust paste and jubilee clips. Then worried about swapping the section over, normally as a summer job.
Post #893534 23rd Mar 2021 8:53pm
cee-b
https://www.gov.uk/guidance/mot-inspection...8-nuisance
Look at 8.1
As long as it is still secure and not deemed excessively noisy, it shouldn't fail. If you're replacing it though, why not use repair paste or a bandage just to get through the MOT with no doubts.
Post #893536 23rd Mar 2021 8:59pm
Mdm
blowing exhaust is a fail.
stainless bit of waste of brass and the sound can be a bit tinny for many folk
Post #893538 23rd Mar 2021 9:09pm
Keith5
Heres the offending seam
I'll have a look for the paste. Keith
Post #893541 23rd Mar 2021 9:16pm
Mdm
tube of exhaust paste from local kwik fit type place or screwfix etc will work as a temp repair.
as long as it aint blowing you should be fine. even if you left the replacement exhaust in the car if it arrives and you cant get it fitted at least the tester knows your gonna fix it
Post #893543 23rd Mar 2021 9:19pm
cee-b
Not according to the MOT testers' manual it isn't. Only a serious leak that affects either emissions or noise.
I've already posted 1 link , here is another: https://www.gov.uk/guidance/mot-inspection...tion-6-1-2
Post #893554 23rd Mar 2021 9:51pm
Julie
Holts gun gum will make it Thumbs Up
Post #893682 24th Mar 2021 7:31pm
