![]() | Home > Puma (Tdci) > MOT & Exhaust condition query |
| markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2704
Can you go old school and buy an exhaust repair thingy from Halfords along with a tin of Dum Dum.
When i was started driving we would use an old Coke tin, exhaust paste and jubilee clips. Then worried about swapping the section over, normally as a summer job. |
| cee-b Member Since: 25 Jan 2018 Location: South West Posts: 117
https://www.gov.uk/guidance/mot-inspection...8-nuisance
Look at 8.1 As long as it is still secure and not deemed excessively noisy, it shouldn't fail. If you're replacing it though, why not use repair paste or a bandage just to get through the MOT with no doubts. |
| Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1696
blowing exhaust is a fail.
stainless bit of waste of brass and the sound can be a bit tinny for many folk |
| Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 357
Heres the offending seam
Click image to enlarge I'll have a look for the paste. Keith |
tube of exhaust paste from local kwik fit type place or screwfix etc will work as a temp repair.
as long as it aint blowing you should be fine. even if you left the replacement exhaust in the car if it arrives and you cant get it fitted at least the tester knows your gonna fix it |
Not according to the MOT testers' manual it isn't. Only a serious leak that affects either emissions or noise. I've already posted 1 link , here is another: https://www.gov.uk/guidance/mot-inspection...tion-6-1-2 |
| Julie Member Since: 07 Oct 2017 Location: La Réunion, Madagascar Posts: 589
Holts gun gum will make it |
| All times are GMT |
